Hi, I`m just tried my first DVD rip with smartripper and DVDAvi, that worked really well. But then the TMPEnc didn`t recognize the files. Could someone please tell me what I did wrong
Thanks a lot
He probably means VOB file.
What you need to do, kawol, is open the .d2v file or the vpavi .avi file.
greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
sorry I meant the .d2v file, that`s the file TMPEnc can not open.
and regarding DVD2AVI, I diddn`t change anything (I have to look at the settings later)
thx anyway
K. -
heh....very common problem..
here's wut you do:
in the folder where your DVD2AVI.exe file is located at, put a file called DVD2AVI.vfp.
then next time u run dvd2avi to make .d2v project file, make sure u do the following:
goto help menu->make sure VFAPI plug-in is checked....after that, tempgenc will recognize the .d2v project file -
Hi poopyhead, thanks for the advice. I played around half the night and read Sefy`s guide one more time and then I gigured it out. And HURRAY, now it worked. I only have to check the Bitrate, the resulting Video is a little bit too large for a CD.
Thanks for all the advice !!
Karin
Laptop IEEE 1394 doesn't recognize camcorder
By NautTboy in forum Capturing and VCRReplies: 4Last Post: 21st Jan 2010, 20:15 -
Doesn't recognize the Blue Ray disk
By bryankendall in forum Newbie / General discussionsReplies: 6Last Post: 18th Jul 2009, 09:15 -
Philips DVP5990/37 doesn't recognize *.divx extension
By picrade in forum DVD & Blu-ray PlayersReplies: 23Last Post: 7th Apr 2009, 13:07 -
Suddenly, burner doesn't recognize blank DVD
By slats7 in forum ComputerReplies: 9Last Post: 13th May 2008, 11:10 -
PSP doesn't recognize format
By rqthrottle2 in forum ffmpegX general discussionReplies: 5Last Post: 6th Jan 2008, 13:32
